Engine Mechanical problem
1998 Chevy S-10 6 cyl Two Wheel Drive Automatic
I have a 98 Chevy S-10. The truck has been running fine with no problems. Came home from work Thursday and now the truck wont crank. Whenever I turned the key on, I would hear my fuel pump kick on but now I do not hear it.. Check all fuses and relays and they are all good. Do I need to replace the fuel pump or is there a fuel pump cut-off switch? It there is a cut-off switch, where is it located?
Feb 14, 2010 at 10:27 AM
