1998 Chevy S-10 Fan belt
1998 CHEVROLET S-10
110,000 MILES • 4 CYL • 2WD • MANUAL
SENTRACJ
How do I change the serpentine belt?
Aug 9, 2008 at 11:22 PM
SERVICE WRITER
  • 9,123 POSTS
Be sure you understand how the belt is wound around the pullies before removing, there may be a diagram under the hood on a sticker, if not draw one.
Release the tension on the belt tensioner using a 3/8" drive socket and backing off the tension. Slip the belt off the puley while holding the tensioner back. Ease the tensioner to a rest position and remove belt. Wrap belt back around following your diagram but keep the most accessible pulley to be the last one. Pull back on the tensioner, slip on blet and release tensioner back to apply tension.
Aug 9, 2008 at 11:54 PM
ROB2008
  • 258 POSTS
Go to this web address and it shows you the belt diagrams and how to change the belt .
https://www.2carpros.com/diagrams
Aug 9, 2008 at 11:58 PM
SERVICE WRITER
  • 9,123 POSTS
[quote:1b9485e9fa="Rob2008"]Go to this web address and it shows you the belt diagrams and how to change the belt .
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800bf924[/quote:1b9485e9fa]
Yeah?...where?
Aug 10, 2008 at 7:02 AM
ROB2008
  • 258 POSTS
You didn't see it at towards the bottom of the page ?
https://www.2carpros.com/forum/automotive_pictures/181498_chevy_s10_1998_1.jpg
1 . On 1998-99 2.2L engines and 1997-99 4.3L engines, using a 3/8 in. breaker bar, rotate the tensioner counterclockwise to relieve the belt tension. On some 2.2L engines it may be easier to attach the breaker bar to the tensioner arm from under the vehicle. 2. Remove the serpentine belt. To install: ]
https://www.2carpros.com/forum/automotive_pictures/181498_chevy_s10_1.jpg
3. Route the belt over all the pulleys except the tensioner. 4. Place the breaker bar and if necessary the socket, on the tensioner pulley bolt and rotate the tensioner counterclockwise to the released position. 5. Install the belt and return the pulley slowly to its original position. Do not let the pulley snap back into position as this may damage the belt and pulley. 6. Check that the belt is properly seated in each pulleyimg]
Aug 10, 2008 at 8:53 AM
SERVICE WRITER
  • 9,123 POSTS
Weird....the link didn't take me ther when I first clicked on it...must be majic or something....
Aug 10, 2008 at 8:15 PM
