1998 Chevy S-10 Engine runs poorly except when A/C is runni
1998 CHEVROLET S-10
175,000 MILES • 4 CYL • 2WD • MANUAL
JTRUDO2
For the past few months, my S-10 has been running very poorly. When driving at speed, the engine sputters like there is water in the gas. At stop lights or stop signs, the engine idles very low and at times will not accelerate out of the stop. The service engine light on the truck would regularly come on and then cycle out when the truck was turned off. It usually took about 20-30 miles for it to pop back up again.
Here's where it gets really interesting for me. My A/C has not been running on the truck for quite a while due to an assumption I made (based on bad advice) that there was a major problem with the system. I decided a couple of weeks ago to try charging the system and it worked! Now I have wonderfully refreshing air!
The greatest result is I have found that when the A/C is running, the engine runs very smoothly with none of the issues I mentioned. It doesn't sputter at speed, die at stops, and the service engine light has not come on once. Can you give me some idea as to what could be causing the problem? I have been told it might be a problem with the A/C sensor, but have never even heard of it. Thanks for the help!
Aug 20, 2009 at 4:59 PM
RACEFAN966
  • 5,029 POSTS
OK you said the engine light has come on? Now with that I would call around to your local parts stores and see if any will do a free scan. Have them scan it and get whatever codes are there then have them clear it. Get back to me with what you find. Have you done any recent tune up or mainenance?
Aug 21, 2009 at 11:21 AM
JTRUDO2
I was planning to hit those places this weekend, actually. The only maintenance that's been done since the problem started is new plugs and wires, oil changes, and cleaning the injectors.
I will get back ASAP with any codes they find.
Aug 21, 2009 at 1:56 PM
RACEFAN966
  • 5,029 POSTS
Ok get back to and let me know what codes are there. If there is no codes then let me know and we go from there.
Aug 22, 2009 at 9:24 AM
