I noticed about a couple of weeks ago, my truck started making almost a tapping like noise. I took it to a repairman and he basically told me I was getting ready to throw a rod. His diagnostic consisted of getting in my truck, starting it, letting it idle for about 3 seconds, and then reving it for about 5. He didn't open the hood. I went ahead and changed the oil, and put 10-40w in it instead of 5-30w. It seemed to help but not too much. If you listen really close to it, it almost sounds like it's coming from the center of the top part of the motor, other times it sounds like it could be under one of the valve covers. My truck isn't losing any power, and if I needed to "stomp" on it to get into traffic, it would easily go, even though right now I'm babying it. I can't figure this out to save my life. Any suggestions? This all did happen the day after I filled my tank up, and it was very slight tapping at first, almost un-noticable. Then I left work that day, and had to get out of someone's way that cut me off, so I had to accelerate kind of quickly and it got a little louder after that.
Jun 13, 2009 at 3:29 PM
