Engine 2200
I replaced the fuse to the Air compressor clutch, clutch started the compressor. I added small amout of freon to the system. The air conditioning blew cold air air in the cab, Job done, right. Not so fast. Drove the vehicle and the fuse blows on the clutch curcuit. Engine RPM more than just idle.
System pressure about 40psi.
Bad coil in the clutch?
How to remove clutch from compressor?
3pc. Delco clutch. coil is separate pc.
Bad compressor?
Bad compressor?
Jun 22, 2010 at 6:59 PM
