1997 S-10 P/UP 4cyl Dome Light flicker during Driving
1997 CHEVROLET S-10
RBRUGGER
Dome light keeps flickering on and off while driving. I hear the clicking by the switch (near fuse access box under dash by drivers door). The switch was replaced when some body repair was conducted. Seems to be connected correctly...although it's tight getting to it. I've heard that bad door bushings may be a possible culprit...how do I know? Any tips/tricks to troubleshoot or replace the bushings or switch?
P.S. Fuse is good...dome & interior lights turn on when door is opened...turn off when closed until i drive down the road a piece.
Thanks
Bob
Aug 16, 2007 at 10:32 PM
CLY
  • 308 POSTS
It could be the door bushings. Are either of the doors sagging? I would check the door jam switchs aswell. Push them in and see if you can wiggle things or tap on things and duplicate the concern.
Cly
Aug 17, 2007 at 5:35 AM
