1997 Chevy S-10 tach hook up
1997 CHEVROLET S-10
43,121 MILES • 4 CYL • 2WD • MANUAL
SNIPS_2121
How do I hook up a aftermarket 5 inch tachometer on my engine,It doesn't have a factory tach,I know it has coils on the lower right side of the motor,Iv'e just never hooked a aftermart tach onto a newer model vehicle....Any help is gre3atly appreciated...Thanks
Aug 10, 2008 at 10:27 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Can you give me the manufacturer of the tach? You will need to splice the ignition control module. There should be a 12V feed to the primary coil and then another wire will feed the coil packs (secondary coils). Between the primary and secondary coils you need to check for 12V. Use a hair pin and stab that line. Connect your tach lead to that pin and then ground the tach with the other end as stated (make sure it says it should be grounded to chasis). Just try it in the engine bay so you can make sure it works before you start splicing and installing.
Aug 10, 2008 at 10:49 PM
SNIPS_2121
Its a Autometer 5inch tach with shiftlight...
Aug 10, 2008 at 10:58 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Did you try the proceedure as I stated before? You might want to look at this wiring diagram and compare it to a wiring schematic of the ignition system in your vehicle. You might need this tach adapter to make the device function properly.
Aug 11, 2008 at 10:50 PM
