1997 Chevy S-10 Power window and Air conditioning not worki
1997 CHEVROLET S-10
PKRODEL
Brakes problem
1997 Chevy S-10 6 cyl Four Wheel Drive Automatic 137K miles
My 97 S10 has a brake light on along with the ABS light on. I may have a mastercylinder failing because sometimes the pedal goes to the floor. My main problem is my power windows and air conditioner aren't working when either light is on. The bake light stays on and the ABS light come on and off. If I try and use the windows or air nothing happens, but the ABS light will stay on or flash as soon as I hit either control. I had the vehicle scanned for codes for the ABS, but only errors were found. I checked the grounds and cleaned up any corroison, but that didn't seem to work. Any suggestions would be much appreciated.
Aug 18, 2009 at 11:48 AM
PEAR69
  • 1,482 POSTS
It sounds like you have several problems. I suggest fixing the errors found with the ABS system, then fix the problem with the brake light...Then see if the other issues fix themselves. Your computer may be overloaded with trouble codes and may need to be re-flashed.
Aug 18, 2009 at 5:10 PM
