1997 Chevy S-10 no warning lights
1997 CHEVROLET S-10
215,000 MILES • 6 CYL • 2WD • AUTOMATIC
KNOTHEAD573
  • 6 POSTS
turn key on will shift without foot on brake no turn signals, no ck engine light, seatbelt,airbag, safety lights,ect.. cranks does not start has spark batt good also obd2 reads err
Feb 19, 2009 at 6:38 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like an ignition switch.Use a test light to see if there is any power to the fuses for the accessories at the fuse block. Check every fuse in the vehicle, underhood and underdash
Feb 20, 2009 at 8:07 AM
KNOTHEAD573
  • 6 POSTS
tried new ignition switch did not work . did you mean ignition assembly? had juice to fuses . thank you
Feb 20, 2009 at 10:13 PM
2CARPRO JACK
  • 11,533 POSTS
Yes, I meant the electric part of the switch, not the tumbler.Sounds like the VCM isnt turning on. There are several fuses and the ignition that power the VCM (vehicle control module). Check for power at pin 16(pink wire) on the VCM to se if it has power with key on.That feed comes from the ECM/IGN fuse
Feb 21, 2009 at 8:01 AM
KNOTHEAD573
  • 6 POSTS
[quote:96a113b799="2CarPro Jack"]Yes, I meant the electric part of the switch, not the tumbler.Sounds like the VCM isnt turning on. There are several fuses and the ignition that power the VCM (vehicle control module). Check for power at pin 16(pink wire) on the VCM to se if it has power with key on.That feed comes from the ECM/IGN fuse[/quote:96a113b799]
Feb 22, 2009 at 10:14 PM
2CARPRO JACK
  • 11,533 POSTS
Did you try the electrical part of the switch? or was it the key tumbler?
Feb 22, 2009 at 10:16 PM
KNOTHEAD573
  • 6 POSTS
rechecked fuses no.s 4,5,10,16,20,& 23 did not work with key on did not find #16 pink wire. will try looking again. it was tumbler, will try electrial thank you.
Feb 22, 2009 at 10:20 PM
KNOTHEAD573
  • 6 POSTS
[quote="knothead573"][quote:60450fba14="2CarPro Jack"]Yes, I meant the electric part of the switch, not the tumbler.Sounds like the VCM isnt turning on. There are several fuses and the ignition that power the VCM (vehicle control module). Check for power at pin 16(pink wire) on the VCM to se if it has power with key on.That feed comes from the ECM/IGN fuse[/quote:60450fba14]
Feb 22, 2009 at 10:27 PM
KNOTHEAD573
  • 6 POSTS
replaced ignition switch everything working just fine now thank you
Feb 23, 2009 at 8:21 PM
2CARPRO JACK
  • 11,533 POSTS
Glad to hear it
Feb 27, 2009 at 7:58 AM
