1997 Chevy S-10 brake line is leaking.
1997 CHEVROLET S-10
DSHOCK13
Brakes problem
1997 Chevy S-10 6 cyl Two Wheel Drive Automatic
one of my brake hoses is leaking.
its on the left side under the driver side door.
is this the rear brake hose?
Mar 7, 2009 at 8:30 AM
MERLIN2021
  • 17,250 POSTS
Yes, steel line. Measure the length and go to the parts store and buy the new line, you may need adapters, at the end at the front. Replace line and bleed rears. Try not to let the master run dry, fill it , then pres pedal down and hold it there with something. Then do the work.
Mar 7, 2009 at 8:47 AM
