1996 Chevy S-10 Stupid Question
1996 CHEVROLET S-10
106,700 MILES • 4 CYL • 2WD • AUTOMATIC
DONJUAN1984
I've done a little work on my truck, but I am by far a good mechanic. I've wanted to fix this for a while, but I really don't know where to start trouble shooting. If you could point me in the right direction, I'd be eternally grateful.
Problem:
After my air conditioner compressor went out on my truck years ago, my heater has been stuck on the feet and defrost position. No matter what I turn the dial to, it will only come out that one position. The heat still works fine, and it doesn't bother me too much... it's just annoying that it doesn't work.
Please help!
Thanks,
Steven
Oct 22, 2008 at 5:21 PM
DOCFIXIT
  • 18,828 POSTS
Truck in defaut mode. Possible reasons no vacuum to slect switch or heater vacuum select switch bad.
Need to remove control unit to check. Do you hesr a hiss from unit when you switch between modes? if so it is the vac switch
Oct 23, 2008 at 1:06 PM
