1996 Chevy S-10 POWER STERRING FLUID LEAKS
1996 CHEVROLET S-10
121,000 MILES • 6 CYL • 4WD • MANUAL
SESZOO
I HAVE POWER STEERING FLUID LEAKING OUT IN THE DRIVER SIDE WHEEL WELL ,I CAN'T RIGHTLY SEE WHERE ITS COMEING FROM,THE ENGINE COMPARTMENT NEAR THE PUMP IS DRY. IS THERE A GASKET OR SEAL THAT COULD BE BAD, THE TRUCK SAT FOR 3 YRS, UNTIL I RESERECTED IT ,THE ENGINE IS DRY ALL A ROUND THE RESERVOIR,ANY HELP WOULD BE APPRECEIATED
Mar 14, 2010 at 9:06 AM
HMAC300
  • 48,601 POSTS
check your powersteering lines, that is usually where they leak. Either it's the clamp on the return line or one of the pressure lines..
Mar 15, 2010 at 12:06 PM
