I need to replace the engine oil cooler lines that go to the radiator.
A Dorman 625-122 hose assembly is called out as a replacement.
The OEM connection at the radiator has a nut on the
oil line end that is held in place with a clip at the radiator connection.
The replacement lines only have a flare and large plastic washer (unknown purpose). The oil filter adapter end looks ok.
Do I just remove the OEM lines, push the flared ends into the radiator connection and install the clip?
Or do I have to buy a dealer part? (say it isn't true!)
The transmission oil cooler lines seem to connect that way at the radiator.
Feb 9, 2008 at 7:15 PM
