1996 Chevy S-10 engine flooding
1996 CHEVROLET S-10
275,357 MILES • 6 CYL • 4WD • AUTOMATIC
AUTOSPUNGE
when i start it it runs rough and puts off black smoke even if you speed up the engine the motor does smooth out but it still puts off black smoke it is getting good air intake through the breather???
Aug 1, 2010 at 4:09 PM
EDWARD.S
  • 166 POSTS
Hi, Have It checked For codes first ,If Nothing Turns up, Then I'd Check The Fuel Pressure Regulator.That Is Inside, Under The Black Plastic Upper intake .The injectors Are Part Of it.Looks Like A Spider.It's A High Failure rate On these Trucks.
Hope This Helps You,
Good Luck
Edward S.
Aug 1, 2010 at 4:45 PM
