1996 Chevy S-10 Clutch Adjustment
1996 CHEVROLET S-10
200,000 MILES • 4 CYL • 2WD • MANUAL
MIXERBERT
I just had the clutch, flywheel, slave cylinder and master cylinder replaced on my '96 S10. When I got the truck back the clutch will not disengage unless the pedal is on the floor and the clutch pedal is slightly higher than it was when I took it to the mechanic. What could cause this, and is there a way to get everything back into adjustment? After 13 years of driving this vehicle, I now feel like I am having to relearn it.
Jan 11, 2010 at 6:16 PM
MMPRINCE4000
  • 8,548 POSTS
Hydraulic clutches are non adjustable, check for leaks and bleed slave cylinder.
Jan 12, 2010 at 7:20 AM
