Transmission problem
1995 Chevy S-10 6 cyl Four Wheel Drive Manual
ok, bought a 95 s10, started to jump and hop when relecing the clutch, brought it to a shop, replaced: clutch, pressure plate, master cylinder, slave cylinder, through out bearing , pilot bearing, and they said the straightend out the fork. now 1 mounth later it is doing the same thing, when i got it back from them the petal had to be stood on in order to disengage the cluth, and would grab about half an inch from the floor, they said it was because it was a new clutch and thicker then the old one. why is it doing it again, did they not install it properly?
Nov 11, 2009 at 7:29 PM
