I literally have to push the clutch pedal "through" the floor to shift out of first or to put in first gear. When the engine is hot, the problem gets worse.
I've changed the following:
Cluch Plate x 2
Clutch x 2
Slave Cylinder
Master Cylinder
In the process of changing the Clutch Fork.
I'm at the back toward the rear-end of the truck and I've unbolted the caps on the U-Joint (differential end). The book says that I should just have to pull the drive shaft free but that is not happening.
I don't want to damage the bearing cap but I'm stuck right now. It appears it's just snug inside the area but I'm not sure...
Cluch Plate x 2
Clutch x 2
Slave Cylinder
Master Cylinder
Sep 11, 2009 at 8:19 AM
