1994 Chevy S-10 need to know
1994 CHEVROLET S-10
124,566 MILES • 4 CYL • 2WD • MANUAL
JERRYSHEPPARD91
  • 5 POSTS
well i dont know how this works so im just going to say it. i had a bad injector so i changed it and now it is holding fuel in the valves i have pulled the plugs and dry fired it for about 30 sec. well then it started but blew gass out of muffler. well changed injector again and it is still holding gas how can i fix it i really need to know it is killing me i allready know it may be the injectors but there all new so i dont know what or how it is doing it.
Sincerly,
jerry b. sheppard,jr
p.s. i wpuld really appreciate it if u could help
Jan 7, 2010 at 11:42 PM
Check the fuel pressure could be excessive due to the pressure regulator and clogged fuel return line
Jan 7, 2010 at 11:49 PM
JERRYSHEPPARD91
  • 5 POSTS
well were is the fuel regulator located and how would i ajust it
Jan 7, 2010 at 11:54 PM
The fuel pressure regualtor is self adjusting-What type of fuel system do you have TBI, MPFI /Vortec???
Jan 8, 2010 at 12:04 AM
JERRYSHEPPARD91
  • 5 POSTS
it is mfi but were is it found the regulator
Jan 8, 2010 at 3:19 PM
Its right along the fuel rail one with a vacuum hose
Jan 8, 2010 at 5:58 PM
JERRYSHEPPARD91
  • 5 POSTS
well ive got the gas to quit running in to the motor but now it isnt starting but the motor will turn over but it will not start.........any suggestions new plugs wires and coil packs
Jan 14, 2010 at 12:49 PM
