I am converting a 1994 s10 to an Electric Vehicle. I have a problem with the tail stop lights. The stop light on the cab works. The white wire from the brake switch has power to the connector at the right side firewall, but there is no power coming to the relay on the firewall. The ground at the relay works. If I jump across the the white wire from the brake switch to the brown and white returning from the relay, the tail stop lights work. But they do not work if I feed current straight into the brown and white at the relay.
The other lights, park, signal, emergency flashers all work fine.
Question: can I by-pass the relay and connect the white to the brown and white at the connector inside the cab?
Dec 27, 2008 at 2:18 PM
