There is an oil pressure switch in the fuel pump circuit. It is a redundant power supply to the pump, wired in parallel with the fuel pump relay, one should not effect the other. Voltage to the load side of relay and o/p switch comes from the same ecm B fuse, you need to be aware of that.
Nov 8, 2010 at 2:40 PM
