Engine Mechanical problem
1994 Chevy S-10 6 cyl Two Wheel Drive Automatic
My truck has been running great previously and then this morning while starting it for the first time today, I heard a loud "pop" under the hood, much like a pressure hose of some type popping off it's fitting. After that, the engine started and immediately went to a smooth, but high RPM in neutral for 15 seconds, then a gradual drop to normal idle but very rough for a few moments then it died. I have tried starting it several times with the same resulting sequence of events. I checked all gauges while running (temp/amps/oil press etc.) all normal.
What do you think? Thanks!
Michael
Michael
May 24, 2009 at 6:06 PM
