1994 Chevy S-10 clutch for a/c compressor not engaging
1994 CHEVROLET S-10
176,000 MILES • 4 CYL • 2WD • MANUAL
SAMIS10
  • 4 POSTS
recently had r & r a/c hoses & mnifld set
evac & charged. was blowing cold, no noises. about a month later, on the way home from work air was warm. full of freon, but the clutch for the compressor not engaging. any idea what I could check? wires, fuseable link?
I greatly appreciate any ideas, or advice... thanks Sani
Aug 3, 2010 at 11:24 PM
Check and test the high and low pressures, magnetic clutch, pressure switch, AC relay and the HVAC control module.
Aug 4, 2010 at 1:11 AM
SAMIS10
  • 4 POSTS
Thank you so much, I will check all that you mentioned & reply. Greatly appreciate your help & time.
Aug 5, 2010 at 1:22 AM
