1993 Chevy S-10 pulled engine
1993 CHEVROLET S-10
220,000 MILES • 6 CYL • 2WD • MANUAL
CHEVYSUCKER
pulled the engine (2.8L V6) Haynes manual said to remove distributor before pulling intake manifold. i did so and put it back in the same position. Now seems as though the truck is out of time at the distributor. We put everything back in (following the manuals instructions) and now when we turn the engine over the belts and pulleys spin but no firing. It has backfired a couple of times though. Please help.
Dec 28, 2008 at 10:58 PM
DOCFIXIT
  • 18,828 POSTS
Put engine at TDC cyl #1 pull plug to verefiy compression and piston travel crank maker should be on poinetr. Pull cap is rotor pointing at #1? If not remove and reposition
Dec 29, 2008 at 9:21 AM
