1993 Chevy S-10 poor mileage and can smell gas
1993 CHEVROLET S-10
95,000 MILES • 4 CYL • 2WD • MANUAL
REESE AND COLLEEN
my truck runs pretty well, starts fine, idles fine but after I stop the engine I can always smell gas. I have replaced the spark plugs, wire harness, cap and rotor, air cleaner and PCV filter. Every once and a while I will come to a stop and the engine will studder but regain its idle.
Oct 17, 2010 at 9:39 AM
HMAC300
  • 48,601 POSTS
try cleaning the throttle plates with choke cleaner as it may be gummming up. Also if you are smelling gas check your whole fuel links for leaks. It may be some slight leakage on the rubber hoses, but shold be looked at. the shudderig may be due to the throttle plate sticking. But also change your fuel fileter as it probably never has been changed. if your check engine light is on have your system scanned for codes as well. Due to this being a pickup you may be leaking fuel from under the bed as one of the fuel lines or rubeer lines going to the tank may be leaking.
Oct 17, 2010 at 11:49 AM
