Please Help!! All gauges and warning light does not work and my battery is not being charge this is what I have done so far First I took the alternator to an advance auto, it passed all test. Then I put it back on, put the test light on the lug I got a light. Ok then I tested the pigtail connector got no light. Tested insturment panel fuse no light on both sides. Then I took the fuse out tested the circuit no light on both sides. Visusal checking of the fuse shows no break. Check all fuses on both sides and I get a light with the exception of the insturment panel fuse and the silver metalic circuit breaker fuses
Sep 21, 2009 at 11:00 AM
