Engine Mechanical problem
1993 Chevy S-10 6 cyl Four Wheel Drive Automatic
I just put a rebuilt 4.3 V6 W series engine with multi-point fuel injection in my 1993 Chevy S-10 blazer. I drove it about 30 miles so far breaking it in. When the oils cold I have 70lbs. of pressure at an idle, but when it warms up it drops to about 10lbs. at idle. I think I'm getting fuel in the oil pan. And possibly thinning the oil too much to hold pressure. I know when we first tried starting the engine fuel flooded the cylinders and fouled out the plugs so it wouldn't start. And the fuel pump wouldn't stop running when we shut the key off and we would have to unhook the battery cable. The fuel pump does quit running when the key is shut off now. I changed the oil before taking it out on the road, to get the fuel out of the oil. But I think it's putting fuel in the oil still, because the oil level seems to be going up and my wife says she can smell gas on the dipstick, my nose doesn't work as good as hers.
What would be causing the fuel to go into the oil pan?
There's no water in the oil, so it must be gas.
If you think the oil pressure may be caused by something else, your advise will be much appreciated.
Thank you
Thank you
Apr 24, 2008 at 9:14 PM
