1992 Chevy S-10 running hot
1992 CHEVROLET S-10
165,000 MILES • 6 CYL • 4WD • MANUAL
BLESSING
no leaks . I don`t know what to do. I changed the thermostat.Still it runs hot.Got heat no leaks there.Thank You
Jan 19, 2008 at 1:09 PM
Try bleeding the cooling system-that don't work get it block n pressure tested to detect a blown headgasket/cracked head and block. Other possible areas could be airflow problem thru the radiator due to clogged-up radiator or a circulation problem with the water pump.
Jan 19, 2008 at 1:17 PM
