i lost the ability to shift my 5 speed all of a sudden coming home from work. i could shift to other gears but would have to FORCE it in. it would make a "grinding gear" noise as it went in,almost like the clutch wasn't disengaging all the way. and as i would let out the clutch it would make the same noise until it was fully released. after making it home in 3rd gear only, i parked it in the yard and now i have NO movement, foward OR reverse. the last time i worked on a clutch they weren't using these "slave cylinders'. so i know NOTHING about them and someone suggested to me that, that might be my problem, now that i have started the removal of my tranny!! though not unbolted from the motor yet, before i proceed any further, what sounds like the problem to you? slave cylinder OR clutch?
Aug 28, 2009 at 1:30 PM
