1992 S-10 Blazer, 4.3L V6. Manual 4X4 engagement(not push button). My problem is that my front differential is stuck in 4WD mode. The vacuum actuator which locks the front diff is receiving constant vacuum even when the shifter is back in 2WD mode. It will release if I pull the vacuum lines off the top of the Xfer case (when the truck is not running) and I can physically hear the cable actuate in the diff, so I know it is moving, and then the light will turn off indicating it is back in 2WD. But as soon as I start the truck back up, the actuator receives full vacuum and we are back locked. My guess is either something with the vaccum switch on the Xfer case, or the vacuum is not releaseing from the Xfer case via a vent or something.
I would appreciate any troubleshooting suggestions.
Thanks
Thanks
Feb 1, 2008 at 1:05 AM
