Engine Performance problem
1992 Chevy S-10 6 cyl Two Wheel Drive Manual
First of all it has the 4.3 ltr V6 with a throttle body. It will idle fine (sometimes) but will not run smoothly after you try to accelerate. It misses and backfires out the exhaust after releasing the gas, and sometimes backfires out the intake while giving it gas. It has new plugs, wires, distributor cap & rotor. The coil and ignition control module both tested good. When the engine is cold it doesn't misfire, but still doesn't have very much power- any ideas?
Aug 29, 2009 at 10:32 PM
