1991 Chevy S-10 6 cyl Two Wheel Drive Automatic
4.3 will not idle have checked throttle position for correct voltage, changed the spark control module ignition module, checked for vacuum leaks, checked map air sensor changed erg valve, replaced plugs and wires. this has straightened out the rough running above idle but it still wont idle what could be causing this please
Oct 14, 2008 at 7:35 AM
