when observing the valves while trying to crank the motor they do not go up and down
i took off timing chain cover and there is no belt or chain it is simply two gear type cogs that turn on each other in no way do these 2 gears seam worn
when observing the two geas when it is being cranked they are turning on each other
so why dont the lifter rise and fall???
Apr 22, 2010 at 3:22 PM
