Raise drivers side of vehicle.. Preferably on ramps. Follow line from the clutch master cylinder to tranny. Where the line goes into the slave cylinder, right above it, is a 12mm bleeder screw. It is easiest if you take the line loose out of the slave cylinder, insert it in a jar of fluid and pump a couple of times. You will notice a lot of bubbles. While doing this make sure the master cylinder does not empty itself. After you see no more bubbles in jar after pumping reconnect to slave cylinder and bleed it the same as you would brakes.
Mar 1, 2009 at 6:49 PM
