1991 Chevy S-10 +battery cable burned
1991 CHEVROLET S-10
MATTHEWALMIGHTY
Electrical problem
1991 Chevy S-10 6 cyl Two Wheel Drive Automatic 140k miles
Went to hook up an old battery that i had on a trickle charge for the past week. connected + cable, then i connected the - cable. The +cable that leads from the battery to the alternator started smoking and glowing red. i quickly disconnected the battery, but the damage was done. What did I do wrong? I did not accidentally switch the cables, as they don't reach the terminals
Feb 20, 2010 at 6:10 PM
If you didn't reverse polarity-you probably have a short somewhere start at the starter solenoid
Feb 20, 2010 at 7:05 PM
FARMSTER38
Most likely a sort in the solenoid which on the newer models are at the starter old truck where on the firewall and then a cable went to starter
Feb 23, 2010 at 9:12 PM
