1987 Chevy S-10 starving for fuel
1987 CHEVROLET S-10
91,587 MILES • 6 CYL • 2WD • AUTOMATIC
DLEE7180
my truck has been sitting for 6years and i put back on the road and its starving for fuel does fine moving around the yard but when u hit the road and mash the throttle it hesitates bad and sometimes cuts off u have to rush the throttle to keep it running at times but i have changed fuel pump,filter,throttle body,and tps sensor and i also drained the old gas out before i started to crank it replaced it with 92 octane help me i have no idea what it is please give me some tips somebody said it could be the map sensor but i dont know could it be and there is no check engine lights on
Sep 20, 2009 at 8:37 PM
DLEE7180
[quote:2f69ccac61="DLee7180"]Engine Mechanical problem
1987 Chevy S-10 6 cyl Two Wheel Drive Automatic 91587 miles
my truck has been sitting for 6years and i put back on the road and its starving for fuel does fine moving around the yard but when u hit the road and mash the throttle it hesitates bad and sometimes cuts off u have to rush the throttle to keep it running at times but i have changed fuel pump,filter,throttle body,and tps sensor and i also drained the old gas out before i started to crank it replaced it with 92 octane help me i have no idea what it is please give me some tips somebody said it could be the map sensor but i dont know could it be and there is no check engine lights on[/quote:2f69ccac61]
Sep 20, 2009 at 8:42 PM
