1985 Chevy S-10 Acceleration
1985 CHEVROLET S-10
199,820 MILES • 6 CYL • AWD • AUTOMATIC
85CHEVYS10
Normally when i drive the truck it dies quite often. I have to put it in neutral at stop lights or else it will die. Sometimes if im turning a corner and have to step on the break it will die. Now I cant even get it around the block. If im lucky to keep the truck running long enough to go somewhere i have to step on the gas pedal all the way and the truck will only get up to 15 mph all the while it is starting to shake and sputter and then it dies. i dont know what this could be caused by? I recently got new spark plugs.
Jul 30, 2009 at 2:54 PM
DANAUTHIER
  • 156 POSTS
There are several things that can cuase these conditions. There stalling on turns could be caused by a shot in the steering collum wiring but shouldn't case the lack of power. A failing torque converter clutch soleniod will cause the engine to die when coming to a stop, putting the vehcile in neutral would take the torque converter out of the equasion and the engine would restart but again should not cause a lack of power unless you also have a transmission issue.
A resrtited exhaust system or clogged catalitic converter would cause the lack of power and stalling condistion. This is checked by first visually checking the exhaust system for dents or other restrictions.
The catalitic converer over heating and glowing red is an indication of a blocked or clogged cat. If you can, disconnect the exhaust before the catalitic converter and try operating the vehicle. I of course will be very loud, but if you drive it with the exhaust separated before the converter and the drivability problems go away than there is a restirction in the exhaust. This could be the converter, the muffler or the piping.
These are just a few places to start, it could also be a fuel issue (when did you last change your fuel and air filters?) , wiring or computer issue...
Let me know,
Dan
Jul 30, 2009 at 3:20 PM
BROOKLIN
Hi, I am recently having similar problems, do you remember how you fixed it? I would really appreciate it, as im gettin really frustrated with my truck
[quote:190d79c050="85chevys10"]Engine Performance problem
1985 Chevy S-10 6 cyl All Wheel Drive Automatic 199820 miles
Normally when i drive the truck it dies quite often. I have to put it in neutral at stop lights or else it will die. Sometimes if im turning a corner and have to step on the break it will die. Now I cant even get it around the block. If im lucky to keep the truck running long enough to go somewhere i have to step on the gas pedal all the way and the truck will only get up to 15 mph all the while it is starting to shake and sputter and then it dies. i dont know what this could be caused by? I recently got new spark plugs.[/quote:190d79c050]
Mar 3, 2010 at 12:18 AM
DANAUTHIER
  • 156 POSTS
What are the symtoms you are having? What is the year, make, model, and engine size of your vehicle? Automatic or manual transmission? Get back to me with a little more information and we will help you figure this out.
85chevys10 never got back to me so I am not sure what he found.
Thank you for the donations and I hope to hear from you soon.
Thank you,
Dan
Mar 4, 2010 at 12:44 PM
