1985 Chevy S-10 about my truck
1985 CHEVROLET S-10
JPMP2009
1985 Chevy S-10 6 cyl Two Wheel Drive Manual
how do i put a distrubutor pick up coil on a 85 chevy s10 i need the pic and instructions on how to put it on
Jun 10, 2010 at 5:02 PM
HMAC300
  • 48,601 POSTS
the distributor has to come out and apart. Just make sure the dot on the distributor gear lines up with the rotor. You'll see once it's out. Make sure to remember where the rotor is pointing when you take the distributor out so you can retime it easily.
Jun 10, 2010 at 6:16 PM
JPMP2009
i got the disputer out and i trying to get the truck coil off how do i take it off
Jun 10, 2010 at 7:43 PM
HMAC300
  • 48,601 POSTS
ok now you have to drive the pin out of the distributor gear on the bottom and pull the shaft out. Make sure to put the gear on the same way when you put it together so mark it. pull th eshaft out and take the module out by taking th two screws out. take teh vacuum advance off and the pickup coil may lift out or it will have a slip ring on the housing holding it on. take that off and the coil then reassemble. I was trying to get a picture off of a site but can't seem to do it. If i can get it i'll send it along.... it's not that hard............
Jun 11, 2010 at 2:04 PM
HMAC300
  • 48,601 POSTS
https://www.2carpros.com/forum/automotive_pictures/406719_G1985 Chevy S-10raphic_4.jpg hope this comes through......
Jun 11, 2010 at 5:13 PM
