on new engine
I had a crate engine installed about 3 years ago and have about 15 thousand miles on the new engine.
When I tried to tune the engine, I found the timing mark to be 14 degrees off, I confirmed this by having a shop tune the engine on their scope.
The best answer I have come up with is that the harmonic balance 'ring' has slipped.
1) Before I go through the process of replacing the harmonic balance, is there a way to verify that this is the issue correct diagnosis?
2) If I do the job, do you think I should replace the water pump?
3) Do you recommend replacing anything else as a matter of course, given the labor involved?
Apr 24, 2008 at 11:27 AM
