turn signals
CHEVROLET
NASCARLOVER340
i have a 1996 chevy s-10 with 128,189 miles. the turn signals stopped working the emergency flasher still works. i have checked the fuse and it is good where is the the flasher located and how do i check it?
Feb 18, 2007 at 3:04 PM
CHEVY22
  • 1,375 POSTS
did you check the bulbs first??if so the flasher is located in the power distribution center , there is a separate flasher for the hazard also in the same location , you can swap the two and see what happens
jim
Feb 18, 2007 at 5:31 PM
NASCARLOVER340
yes i checked bulbs. where is the power distribution center ? and are the flashers marked so i know i try the right one?
Feb 18, 2007 at 6:45 PM
CHEVY22
  • 1,375 POSTS
power dist box is under the hood and yes they should be marked on the cover , hope this helps
jim
Feb 18, 2007 at 9:02 PM
CHEVY22
  • 1,375 POSTS
i forgot you may have a split year truck and the turn may be under the right dash , under the glove box , depends on the production date, sorry , i just remembered the split
jim
Feb 19, 2007 at 7:28 AM
