Temp guage says hot but engine seems OK
CHEVROLET
EFRAIN108
  • 5 POSTS
1992 Chevy Suburban (350, 2 wheel drive, auto) with 135000 miles. Cooling system sprung a leak. I replaced the thermostat housing, gasket, new theremostat, new radiator cap. I flushed system, added new 50% coolant. I replaced temp sending unit. Temp guage fluctuates. Goes up high, but I check the engine and it does not feel hot. No steam. I can actually put my hand on intake manifold. Top hose is hot but normal. Could it be the water pump or radiator? This wasn't doing this before springing a leak and my doing all this work.
Nov 6, 2006 at 12:38 PM
BUELLXB9RFB
  • 50 POSTS
replace the engine temp sensor .. should fix your proble .. located on the block .. alot of time when they spring a leak if not shut down soon enough it can mess up the engin temp sensor
Nov 6, 2006 at 6:26 PM
EFRAIN108
  • 5 POSTS
Thanks. I replaced the sensor (the last thing I did) but problem persists.
Nov 7, 2006 at 10:04 AM
BUELLXB9RFB
  • 50 POSTS
try undoing your battery for 30 sec .. sometimes the gauges can get stuck ..
Nov 7, 2006 at 9:19 PM
EFRAIN108
  • 5 POSTS
I haven't tested with a voltmeter. I can do that. The guage starts normal, then goes to hot, stays there a while, then comes back to normal for a while, then hot again, etc. I've noticed that if I stop and turn the engine off when the guage is very hot, then turn it back on, the guage goes back to normal. I have also noticed smoke when accelerating after being stopped at a light.
I'll also try disconnecting the battery. Heck, I'll even dance around the truck a few times if it'll help. (jk) Thanks.
Nov 8, 2006 at 1:47 PM
BUELLXB9RFB
  • 50 POSTS
what color is the smoke that your seeing . and does it have a rough idle at all ?
Nov 8, 2006 at 5:43 PM
EFRAIN108
  • 5 POSTS
The smoke looks blue-ish, although I have only looked at it through the outside mirror and the mirror may be tinting it. The idle is very smooth.
Lately, the temp guage now goes from cool to hot, from one extreme to the other, and stays at hot. If I turn the engine off and back on a few seconds later, it goes back to normal (mid range).
I appreciate your staying with me on this.
Nov 9, 2006 at 12:16 PM
