Spark Plug Removal
CHEVROLET
DALEHILL
I have never changed the spark plugs on s-10 blazer 6 cyclinder 2 wd. Should I expect any difficulty? Shoudl I use anti sieize on the new plugs?
Dec 31, 2006 at 2:09 PM
SERVICE WRITER
  • 9,123 POSTS
Use dielectric grease on the inside of the spark plug wires, Lightly coat the plugs with anti-seize, Double check for the correct application of the plugs.
There is one plug that is a mother on the driver's side. Bring your patient side with you on that one, The steering column is right in front of it.
Second I have had very good luck changing the plugs out by loosening the lugs on the two front wheels then jack the car up and put it on jack stands, then take one tire at a time off and you can gain access to the three plugs on that side through the inner fender well opening. Then do the same to the other side. It is much easier that doing it from above.
Dec 31, 2006 at 5:41 PM
