I HAVE A 96' SUBURBAN 5.7 143000MI
THE FUEL PUMP QUIT SO I REPLACED IT. THE NEW RAN FOR FIVE MINUTES AND QUIT. UPON REMOVING THE NEW, I RAN HOT AND GROUND DIRECT TO PUMP OUT OF TANK AND THE PUMP WORKED. ALSO THE PREVIOUS PUMP WORKED THIS WAY. MY CENTER PRONG WIRE AT THE PUMP READS 8.4V AND NO VOLTAGE AT THE GRAY. MY HAYNES MANUAL DIAGRAM SHOWS ORANGE FROM THE RELAY TO AN OIL PRESSURE SWITCH, THEN GRAY TO PUMP. I CAN'T FIND SWITCH TO FIND THE GRAY WIRE AND THE VOLTAGE LOSS.
OR COULD IT BE SOMETHING ELSE. FUSE IS GOOD AND NEW RELAY INSTALLED. MY CODE READER SHOWS MAV CIRCUIT LOW?
Dec 30, 2006 at 6:14 PM
