light problem
CHEVROLET
WELDOR
I have a '92 chevy S-10 all the lights worked great until yesterday when the fuel pump went out I removed the bed and installed a pump when returning the bed I noticed the rear lights dont work I went thru all the wiring and fuses could this be a flasher problem? I have front turn signals but both rear flash, then with the lights out I have tail lights and with them on I have nothing. the hazard flasher works fine but it makes the plate lights flash please any advice would be helpful I have chamged all bulbs and went thru wiring from front to back. I have juice back there and I even changed harness but no luck I need help :? Thanks
Sep 27, 2006 at 9:28 PM
WELDOR
hey all I found the problem after wiring the truck from the fuse box back it was a shorted out ground wire but hey at least I have all new wires now but thanks anyway and good luck with all your vehicle problems
Oct 1, 2006 at 9:47 AM
