Heater Problem's 93 Pickup?
1993 CHEVROLET
DODGER#1
  • 9 POSTS
1993 Chevy Pickup Chyene 1500 V6: I'm having a problem with my heater. The problem with it is that when i turn it on it blows cold air only through all the vents. Put when i put my thermostat to hot air it wont throw the hot air in.There is no vaccum hoses broken nor anything leaking. Can u guys help me out? And Thank u.
Dec 13, 2006 at 8:30 PM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like the heater core is clogged. How is the car running reguarding the temperature. If its running cool then the thermostat is either struck open or has been removed .Are you the original owner? BYM
Dec 15, 2006 at 1:22 PM
DODGER#1
  • 9 POSTS
The tempature is running fine.nor any thermostat has been removed. It just stop heating when i turn on the heater. It turns on but just cold air comes out. And yes im the original owner.
Dec 16, 2006 at 12:48 AM
BACKYARDMECHANIC
  • 337 POSTS
Check that the heater control valve (if equipped) is opening if this is operating correctly than you need to flush the heater core. Do this by removing both hoses from the heater core and using a garden hose. Continue to flush until you have a good flow.
Dec 16, 2006 at 6:56 AM
