engine miss at light throttle
CHEVROLET
CALEBZX9R
I have a 1995 suburban k2500 5.7l with 125000 miles
when it is cold it starts hard and misses for about a minute then idles fine. while driving, when i get up to speed and am giving it light throttle is misses pretty bad. if i let off the throttle, or give it more throttle is goes away. there doesnt appear to be loss of power at full throttle. i replaced the fuel pump about 1500 miles ago and i just replaced the fuel filter again. please help
Jan 22, 2007 at 12:34 AM
CARUNDELL
  • 602 POSTS
[quote:6c6aa2812e="calebzx9r"]I have a 1995 suburban k2500 5.7l with 125000 miles
when it is cold it starts hard and misses for about a minute then idles fine. while driving, when i get up to speed and am giving it light throttle is misses pretty bad. if i let off the throttle, or give it more throttle is goes away. there doesnt appear to be loss of power at full throttle. i replaced the fuel pump about 1500 miles ago and i just replaced the fuel filter again. please help[/quote:6c6aa2812e]
Hey caleb,
Sounds like you may have a bad plug wire or plug. When was the last tune up? Let me know!
Chris
Jan 22, 2007 at 11:48 AM
CALEBZX9R
I changed the plugs, wires, cap and rotor about 2000 miles ago. I also changed the MAP sensor.
thanks for the quick reply
Jan 22, 2007 at 12:28 PM
CARUNDELL
  • 602 POSTS
[quote:18383f0a82="calebzx9r"]I changed the plugs, wires, cap and rotor about 2000 miles ago. I also changed the MAP sensor.
thanks for the quick reply[/quote:18383f0a82]
Hey,
I would carefully inspect those ign wires for chafing or failure, especially @ the plugs .... you can also get a spray bottle w/ water and kind of hose down the cap and all the wires, look for arcing or a stumble in the engine. Was the map sensor changed because the old one failed or did you do that as a maint. item? Also check all the vacuum hoses and lines for cracks or breaks, a vacuum leak will also cause a skip (lean misfire) Another possibility the O2 sensor has failed or close to failure. But you would need a scanner do diagnose that one properly! Let me know!
Chris
Jan 22, 2007 at 12:39 PM
