engin hesitation, failure to start
CHEVROLET
ROLAND HEWETT
I have a 1999 suburban k1500 w/5.7 liter engine 90k miles. Last dec I replaced fuel injectors, pcv , egr valves, distributer cap, wires and spark plugs, last week the fuel filter. 2 days ago the engine light brieflywent on as I was traveling at 60 mph and the truck started to hesitate. After pulling over and letting the truck sit for 30 minutes, the truck would not initially crank just turnover, When I had the fuel filter replaced I did a machine diagnostic test no codes popped up and the fuel pressure was 56 psi. Could this still be a fuel pump problem? Can weak valve springs cause a similiar type of problem and if so would the engine throw a code? Any help would be appreciated.
Dec 13, 2006 at 9:22 PM
CARUNDELL
  • 602 POSTS
[quote:c6a8a00d7c="Roland Hewett"]I have a 1999 suburban k1500 w/5.7 liter engine 90k miles. Last dec I replaced fuel injectors, pcv , egr valves, distributer cap, wires and spark plugs, last week the fuel filter. 2 days ago the engine light brieflywent on as I was traveling at 60 mph and the truck started to hesitate. After pulling over and letting the truck sit for 30 minutes, the truck would not initially crank just turnover, When I had the fuel filter replaced I did a machine diagnostic test no codes popped up and the fuel pressure was 56 psi. Could this still be a fuel pump problem? Can weak valve springs cause a similiar type of problem and if so would the engine throw a code? Any help would be appreciated.[/quote:c6a8a00d7c]
Hey Roland,
Fuel pressure is a definite possibility and those pumps are a common issue. Weak valve springs is possible but remote. I would recommend re checking fuel pressure and get the truck re scanned and we'll go from there.
Chris
Dec 14, 2006 at 5:04 AM
