EGR Hose?
CHEVROLET
DABOSS
  • 5 POSTS
I got a 1997 Chevy Lumina, 120,400 miles on it, she still runs, but my question is this, there's a hose-like pipe from the bottom of the EGR Valve to the Intake Manifold, can that be tooken off? might sound dumb, nut I gotta know. I wanna clean it out and see if that'll fix the problem because I got the P0401 engine code, Insufficient EGR flow. someody let me know.
Jul 4, 2006 at 11:05 PM
MIKEYBDMAN
  • 623 POSTS
If no modifications to the exhaust system have been made, then inspect the exhaust system for leaks. If no leaks, remove the EGR valve and insp the pintle, valve passages and adapter for excessive deposits or any kind of restriction. Check EGR gasket for leaks or pipe leaks.
If no problems, remove the EGR inlet and outlet pipes from the manifold and insp ports and pipes for deposits, or obstructions.
If that doesnt help, you are going to have to start chasing wires.
Jul 8, 2006 at 2:47 PM
POPALONI
CHEVY
LUMINA
1997
I WAS WONDERING WHAT YOU HAD TO DO TO YOUR CAR? HAVING SAME PROBLEM AND DUE FOR EMISSIONS AT END OF MONTH.
THANKS, PAUL
Oct 19, 2006 at 12:45 PM
