Chevrolet exquinox
CHEVROLET
DELEGARITO
I get P1630 on my scanner what are the possible problems
Jul 19, 2007 at 8:41 PM
CLY
  • 308 POSTS
Has the Body Conrol Module been replaced???? Will the car start???
Cly
Jul 20, 2007 at 5:24 AM
DELEGARITO
[quote:68d3a94471="Cly"]Has the Body Conrol Module been replaced???? Will the car start???
Cly[/quote:68d3a94471]
Jul 20, 2007 at 10:27 AM
CLY
  • 308 POSTS
I think something didnt work right on your last post there.....
Cly
Jul 20, 2007 at 3:16 PM
DELEGARITO
[quote:1344601aed="Cly"]I think something didnt work right on your last post there.....
Cly[/quote:1344601aed]
Hallo the car started but shut down when check engine light goes on and the only code i receive is P 1630
Yhanks Rudolf
Jul 20, 2007 at 5:40 PM
CLY
  • 308 POSTS
ok....We can try and do a relean for the theft system but there may be a problem with it....
NOTE:::::You will need to connect a battery charger to the car for this 30 min relaern.....
30-Minute Learn Procedure
Important: Do not remove the key from the ignition during this procedure. If the key is removed, the procedure will have to be performed from the beginning.
1..Turn ON the ignition, with the engine OFF.
2..Attempt to start the engine, then release the key to ON. The vehicle will not start.
3..Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF.
4..Turn OFF the ignition, and wait 5 seconds.
5..Repeat steps 1-4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important: The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6..Start the engine. The vehicle has now learned the Passlock™ Sensor Data Code and/or password.
7..With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
Have you replaced any parts or got new keys or anything?????
Cly
Jul 20, 2007 at 6:32 PM
