brakes
CHEVROLET
ADIRANUS
i have a 1993 chevy g-20 van with 130,000. the left front caliper stays compressed causing the van to pull to the left. when i step on the brake the van pulls to the right extreemly hard, which tells me there is no pressure going into or out of the caliper. i have changed the caliper and the master cylinder but no change. i did notice the abs wheel sensor wire was rubbing on the tire but the wire is not broken.
Nov 4, 2006 at 4:40 PM
ADIRANUS
if i jack up that side of the van the wheel is very hard to spin by hand. if i loosen the bleeder valve it releases the pressure and i can spin it and it will spin on its own. i will try changing the hose. could it be the proportioning valve? the abs light is on as well. the hose is cheeper, i'll try that first.
thank you
Nov 7, 2006 at 4:01 PM
