Without having the pads in front of me, it's hard to know if this is the case or not. I know I tried putting the wrong pad in the wrong position and couldn't do it until a tech straightened me out. :oops:
The shap of the linings should be somewhat sei-cricular with the smaller radius to the hub. The tab I refer to is part of the metal backing and is on top. The offset can be seen on the caliper as to why they are different. NOTE: This may not be your case. I just remeber they were gm pads I had trouble with.
You may have the wrong rotor also? For fun :roll: , throw the old rotor on and see if they fit. ( I know it will be thinner and may accidentially work, but this is for fun :) .
Match up the old pads and rotors VERY carefully and see if there is any difference.
The rotor has to turn freely.
What brand and part numbers do you have?
Dec 28, 2006 at 8:54 PM
